Yes, mine is built in a LLT/LFX block. Yes from speaking to my friends in GM Engineering, They had said the main caps are stiffer, there is a tad more meat around the cylinder liners, but otherwise its mostly cast in provisions for the turbo fluids, as he noted the crankshaft is stiffer than the LLT/LFX counterpart also. Same as myself, I used the coolant returns on the head, and made my own coolant feeds to them. I fabricated my oil pan also, though I am not overly happy with it (My first time fabricating an aluminum pan) and I will likely revisit it for next year. That being said, with the new pan I bought to cut up, the aluminum material and consumables with the TIG, I have about $600CAD in this damn oil pan :suspense: lol, the fun of building these motors when there are no off the shelf options!
Speaking of which, working on updating from a lesson learned when I didn't pay attention to the size of tubing I was using (I should know better) which is too small (2.5") for the slot MAF's to have accurate readings. So now I am working on redesigning the forward halfs of them in a larger diameter tube. Also revisiting my hood latch setup, the oil lines to the filter block, the entire oil cooling system, and a few other little things. Trying to get it to a point where I can actually drive it in between these updates LOL.
Anyway, I put one of my mockup splitter's on it again so I can think out a few possible design changes, and otherwise I am continually fit checking everything.
Made a few changes on fluid line routing, but damn real estate is at a premium!
Finally decided on a solution to my fuel supply concerns (Excuse the hose clamped joint in there, temporary) and ended up with a dual pump setup. Ive written software for an Arduino Uno to control it. Thankfully the RX8 divides it's fuel level sensors, with one on each tank in series. Another stroke of luck, the passenger side of the tank is first in the series, so the Arduino is monitoring the fuel level in the passenger side of the tank to control the secondary transfer pump which will shut down power once it empties the passenger side of the tank. The RX8 OEM setup is terrible at best, and barely supports the Renesis Rotary engines fuel demands, which has them notorious for running out of fuel when the gauge still reads 1/4-3/8 full. The original setup passes returned fuel through a venturi pump to draw fuel from the passenger side of the tank. In all of my experience so far, I have yet to have a good experience with a return venturi pump system keeping up with consumption on the drivers side so I have been back and forth trying to decide what to do. Unfortunately I cannot afford a kickass surge tank with twin external pumps, so this will do for now. Essentially the second pump is just transferring fuel to the drivers side as long as its level is above my specified level resistance.
The first bashbar I made up for my RX8 is now going onto my buddies drift car. Finally a first variant of one of my parts see's use on another RX8 rather than the scrap bin!
Hopefully soon I can post a video of it making some noise!!
