Was curious how they worked compared to my Z06's bi-mode exhaust working off vacuum and obviously some electronics to open/close at certain rpms in stock form. Many years ago I installed the 'Mild to Wild' switch which is cool to have especially with the Akrapovic exhaust I have.
Over the weekend I removed the passenger side electronic actuator to see how it works since it doesn't seem to work off vacuum as my Z06 does. Found out there is a heavy spring that keeps the valves open. Once the car is started, after a few seconds, the actuator closes the valves then reopens depending on the signal it receives during WOT, Sport, Race, etc.
Many of us that have removed the cats and installed aftermarket DP's are not thrilled with the WOT sound of the stock muffler at certain rpms. I'd like to be able to keep mine a sleeper hence the reason for the post.
I wonder if there is a way to keep the valves closed at WOT? Until a quality exhaust system comes out with a better, tuned (non obnoxious) WOT sound, with ZERO drone and quiet during 'normal' driving I'd like to be able to keep the valves closed at all times. Other than the obvious, trying to remove the spring (not sure how after looking how it's integrated) then figure a way to physically block the valves from opening, I'm not sure how to go about doing this.
I'm sure the BCM is part of the equation as nothing we've seen in the ECU has a function to be able to turn on or off the electronics responsible for the opening or closing of the valves.
Any thoughts or suggestions...??
