If your car is anything like mine, the wheels/tires cant hold the power the motor makes. Maybe I lucked out with my car, but I spin the rears mid-way through first gear, between 1-2 shifts, and sometimes when the car downshifts under full throttle. My search for a taller/wider setup which would hold the power led me to do a lot of research and a unique setup for my car. I have a 2017 stock V sedan A8. This write-up applies only to the sedan.
Factory Wheel Info
Sedan Factory Front: 9” x 18” / 28 mm offset / 120x5 bolt pattern
Sedan Factory Rear: 9.5” x 18” / 48 mm offset / 120x5 bolt pattern
Coupe Factory Front: 9” x 18” / 28 mm offset / 120x5 bolt pattern
Coupe Factory Rear: 9.5” x 18” / 36 mm offset / 120x5 bolt pattern
Sedan vs Coupe Rear Wheels
The coupe rear wheel offset places it more ‘outward’ vs. the sedan. Factory rear coupe wheels mounted on a sedan will stick past the fender – as will aftermarket / wider rears setup for a coupe. These are wider coupe wheels on my sedan (they didnt “tuck-in” when the car was lowered to the ground). These wheels sit flush with the fender on a coupe:
Factory Tire Info
Original Equipment: Michelin Pilot Super Sport
Front: 255/35ZR18 (94Y) XL / TPC Spec / Tread: 8.5/32” / Diameter: 25.0”
Rear: 275/35ZR18 (99Y) XL / TPC Spec / Tread: 8.5/32” / Diameter: 25.6”
For comparison, a 2017 Camaro SS (455hp & 455tq) runs a 275/35/ZR20 rear / Diameter: 27.6” / 2” taller!
Larger Wheel Fitment - Rear
Here’s the rear (no I don’t have pink rotors, I had a red-ish towel on the ground)
The metal body frame is the limiting area. There is stiff ‘felt’ material above the frame, which is soft… the frame not so much.
Doing the math, you can fit:
10.5” rear wheels, ideal offset: 60-62mm.
With this offset, the wheel is 1” more inward (moves toward the suspension / less clearance between wheel and suspension); no change outward (fender side). Stated another way: With this offset, the extra inch of wheel width goes under the car, while the face of the wheel stays at the same position as the factory wheel face.
11.0” rear wheels, ideal offset: 54-56mm.
This is 1” more inward (suspension side); 1/2” more outward (fender side).
This will stick out a little past the fender lip - you’ll need to decide if you want the wheel sticking out 1/2” past stock.
10” rear wheels, ideal offset: 54mm.
This is 1/2” more inward (suspension side); no change outward (fender side). Obviously, there are more offset options to play with for a 10” wheel.
Larger Wheel Fitment - Front
Here’s the front:
The limiting area is the wheel lip to strut tower (metal) clearance. There is more room (higher up in the picture) for a wider tire/tire bulge.
9.5” front wheels, max offset: 27-29mm.
This is 1/4” more inward (suspension side), 1/4” more out-board (fender side)
Wheel Offset Calculator here:
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Testing My Setup
The above is all theoretical, let’s see if the math actually works.
It is very difficult to find aftermarket wheels for this car – in the right bolt-pattern, in the very high offset needed, and in a style that matches the car's looks, short of very expensive custom forged wheels. I love the way the factory wheels look, so I ended up widening factory rear wheels. Yes, to widen wheels, the wheel is cut near the outside edge and a new ‘barrel’ is welded on. There are only a few companies in the country that can do this and have a good reputation. Luckily, I’m driving distance from one of them: Eric Vaughn Machine in Socal – they specialize in wheel widening. This is the 3rd car I’ve widen wheels on from Eric, including a Z06 which I tracked (HPDE). So I’m very comfortable with this option.
My car came with silver wheels, I wanted to switch to the factory Gray wheels and widen them. Before I bought four new wheels, I widened a test wheel 1” and mounted a 295/35/18 PSS (repro wheel and used tire) – to check that the wider wheel + wider tire would fit.
Test wheel
Taped up to test for rubbing
This setup fit perfectly, no rubbing, and sits flush with fender. Note that this is with this specific tire. YMMV.
My Final Setup
9” stock fronts, 265/35/18 PSS (did not widen fronts). 275s will fit in the front.
10.5” widened rears, 295/35/18 PSS. 305s will fit in the rear.
10.5” Rear (wheel width is measured to the inner wheel lip)
Old rear vs new rear:
Traction improvement is amazing. Rears don’t break loose except the very top of first in perfect weather. I can confidently go full throttle anytime. Car feels much more planted. I tested the traction management/active handling, (in a wet empty parking lot) – no issues as the front and rear tires increased in height by the same amount. Very happy with this setup!
