You didn't mention the year of the ATS but if you get a car with the 8spd auto, make sure it drives well or has had the TSB done on it. They are known for rough 1-2 shifts and the TSB calls for a fluid change, trans tune reflash, and I think new torque converter. Seems to fix it for some, while others continue to have issues. Sunroofs seem to be hit or miss with proper functionality/keeping water out so check that out (drain is above the transmission so not fun to clean out). Also the HVAC system in the ATS kind of sucks but it's usable - more of a general FYI there. The 3.6 itself seems pretty reliable, and sounds good.
