Hi everyone, first time doing this, I have a 2013 ATS 2.0T 130,000 miles and I am stumped. I got the car for cheap as it was sitting for a while and needed work. Got it running and been driving it trying to get the kinks out. Was throwing a lean code and I replaced spark plugs, pcv valves, upstream o2, and a MAF sensor. Turns out the vacuum lines for the motor mounts might have had a small crack in it. So I plugged that vacuum line and haven’t gotten the lean code back yet. (Haven’t driven it enough for the fuel system monitor to set/ go through its cycle) It’s throwing pending codes p0133 and p0137 currently. Also I should say that mostly on cold starts if left idling for more than a minute it will start to misfire and then stall out. My scanner shows that it misfires on every cylinder. I’ve been a mechanic for the last 14 years and this has me stumped. Any help would be greatly appreciated
