At the back of the switch panel is a notch. Insert a long, thin bladed screw driver in it, and push almost straight down (slight angle under the panel). This will push a spring clip forward and release the panel. Once that's lifted out (hook at front, clip at rear), 2 phillips screws on a large bracket are visible. Pull those, and then look under the 2 light fixtures for the other 2. Pop the cover like you're going to change the bulb, and then sqeeze together the 2 clips that hold the whole fixture in. Once it's pushed out of the way, you'll see the other 2 screws. On second thought, pull the 2 BACK screws first, or you'll drop the armrest on your head like I did... Hope that helps.
