1990 Sedan de Ville 1995 eldorado 2000 buick century
i have a 1990 deville 4.5 i used the puller and got it just about all the way off but i cant get it to clear the frame to get it all the way off any suggestions???
2008 SRX
Carefully lower the front of the frame. Some guys lower the right side, but to me, that makes the engine come close to the right frame rail. I support the front of the frame, remove the front bolts and loose the center bolts. This allows you to adjust the body to frame postion so the crank pulley will clear.
Cadillac Deville 1990
It makes it easier if you raise the car and place stand under your frame then loosen the bolts and raise the car pulley should clear the wheel well, I just did it and it worked like a charm.
