1 - 10 of 10 Posts
2009 CTS-V
Hey everyone, I was wondering if there was anyone in the philly area that would be interested in taking a look at a black diamond V for me? It's at Spencer Chevy. I just wanted to see how the tires were, and how the paint is ie major rock chips. I can tell that the Alcantara wheel and shift know are matted but a little elbow grease and sonax will correct that. Piano black needs a polish. I noticed that this 2012 has 2 piece rotors also. Any help would be appreciated.
Rich
Hello Rich, I sold my V about 2 years back but am still an avid enthusiast. There are a few common issues with these cars that the casual observer would not notice. I think I'm qualified to give you a solid PPI. Send me your contact info via PM. I'll try to look at it later Thursday or Friday. Glad to help. Spencer is about 30 miles from me.
2009 CTS-V
Hey brother, thank you for the response! I am actually flying up there today to look at it. I am coming from a 2009 V sedan so hopefully I won't miss anything! Any advise you could give me would be great. Thank you for the response!
Nice of you to offer, Eric.
2018 CTS-V Black Raven, Carbon Package, Recaros
I ran the VIN through GM warranty system and it has had some work completed for sure.
Vehicle Information
VIN: 1G6DV1EP7C0145719Model: 6DN47-2012 CTS-V SERIES
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Transaction HistoryView Details
09/18/2014354922ZREG----Regular Vehicle Transaction2020682 - Front Side Door Window Adjustment 25,412 MI
09/18/2014354922ZREG----Regular Vehicle Transaction7030010 - Front Seat Cushion Ventilation Blower Replacement 25,412 MI
09/18/2014354922ZREG----Regular Vehicle Transaction1042980 - Front Side Door Trim Panel Replacement 25,412 MI
09/18/2014354922ZREG----Regular Vehicle TransactionF9709 - Drain and Refill Rear Axle Fluid 25,412 MI
06/06/201432263ZREG----Regular Vehicle Transaction0600503 - Cadillac Premium Care - Oil Change 23,895 MI
03/07/2014342917ZREG----Regular Vehicle Transaction0600503 - Cadillac Premium Care - Oil Change 20,329 MI
11/11/2013381852ZREG----Regular Vehicle Transaction0600503 - Cadillac Premium Care - Oil Change 17,411 MI
09/30/2013412945ZREG----Regular Vehicle Transaction1033810 - Front Floor Console Transmission Shift Opening Trim Plate Replacement 15,254 MI
09/30/2013412945ZREG----Regular Vehicle Transaction8033640 - Shock Absorber, Shock Absorber Component, or Spring Replacement 15,254 MI
06/26/2013376068ZREG----Regular Vehicle Transaction0600503 - Cadillac Premium Care - Oil Change 11,404 MI
06/26/2013376068ZREG----Regular Vehicle Transaction8460290 - Manual Shift Auxiliary Position Switch Replacement - Steering Wheel 11,404 MI
06/26/2013376068ZREG----Regular Vehicle TransactionAdd Credit 4068410 - Supercharger and Gasket Replacement 11,404 MI
06/26/2013376068ZREG----Regular Vehicle TransactionFull Debit - Reversal 4068410 - Supercharger and Gasket Replacement 11,404 MI
06/26/2013376068ZREG----Regular Vehicle Transaction4068410 - Supercharger and Gasket Replacement 11,404 MI
01/24/2013369326ZREG----Regular Vehicle TransactionJ3254 - Radiator Surge Tank Inlet Hose Replacement 6,742 MI
01/24/2013369326ZREG----Regular Vehicle TransactionH9752 - Clean Mating Surfaces of Wheel and Rotor to Correct Noise Concern (Both Sides) 6,742 MI
01/24/2013369326ZREG----Regular Vehicle TransactionAdd Credit J5908 - Supercharger Assembly - Replace 6,742 MI
01/24/2013369326ZREG----Regular Vehicle TransactionFull Debit - Reversal J5908 - Supercharger Assembly - Replace 6,742 MI
01/24/2013369326ZREG----Regular Vehicle TransactionJ5908 - Supercharger Assembly - Replace 6,742 MI
11/14/2012439092ZREG----Regular Vehicle TransactionH9752 - Clean Mating Surfaces of Wheel and Rotor to Correct Noise Concern (Both Sides) 3,451 MI
11/14/2012439092ZREG----Regular Vehicle TransactionJ6472 - Heated Oxygen Sensor Replacement - Bank 1 Sensor 1 3,451 MI
08/25/2012434618ZREG----Regular Vehicle TransactionH9766 - Replace Both Front Brake Rotors to Correct Noise Concern 1,135 MI
08/25/2012434618ZREG----Regular Vehicle TransactionN6653 - Wire-to-Wire Repair 1,135 MI
04/03/2012289532ZPDI----Pre-Delivery InspectionZ6999 - PDI Related Fluid Adds 5 MI
03/22/2012A45719ZPDI----Pre-Delivery InspectionZ7000 - Pre-Delivery Inspection - Base Time 1 MI
Job Card DateJob Card NumberTransaction TypeTransaction AdjustmentLabour OperationOdometer Reading
Gone; ‘09 V, ‘13 V coupe. Curr; ‘14 PG Vsport prem w/Kona interior
Looks like the SC was replaced twice, or am I reading it wrong. They apparently upgraded to the two piece rotors when the rotors were replaced. Nice bonus.
That's what I read. This ride should be good to go - and go fast!
you're probably seeing the car right now.. I'm late to the game here.
Have them put the car up on a lift. See if there is any power steering fluid leaking from the cooler lines that are below the driver's side headlight. This can also be seen thru the front grill area if you put a light on it. Minor detail but it'll be a nice discount negotiator.
Tires? Brake pads aren't cheap for the Brembos. Hopefully new pads went in with the 2-piece rotors. Verify.
Examine the headliner carefully for any discoloration/water penetration.
Turn on every electrical gadget electrical and let it idle for 10+ minutes. Any odd oddities or oil burning smell. The supercharger replacements are fairly straightforward for a competent tech but...?
Shocks-- any signs of leakage? I only had one minor with one of mine in 44k miles.
What kind of music was in the HDD? Ha!
These cars are fairly bulletproof-- even if abused. Cosmetics says a lot to me and that is in the eye of the beholder.
Good luck.
1 - 10 of 10 Posts
