1 - 8 of 8 Posts
1983 Fleetwood coupe
my Fleetwood likes to rev on its own at stop lights and sometimes will lose power will accelerating up hills, I'm pretty sure its the TPS but I wanted to get you all's opinion.. any thoughts
yes... I believe its the check engine light. it says service soon, and will go on and off while driving
1989 Cadllac Brougham
I see, what you should do is to make a system diagnostic and see what error code the computer has registered, i am not sure if the 83 Fleetwood Coupe has OBD1 Diagnostic system, or if you have to pull the diagnostic codes from your ECC panel.
1980 FBC
OBD-1? Not hardly.
Time for a service manual.
Been 30 years but IIRC you can read throttle angle on the HVAC control head with the right button pushes.
If not time for a VOM. TPS failure is just like a scratchy old volume control on a radio. It runs into a dead spot and sends the wrong voltage to the ECM.
Carnut knows this stuff in his sleep...........
You should be able to just pull codes thru climate control for those years.
Can anybody post pictures of where the tps is located on these cars, I have the part but am waiting for an owners manual (which will be 1-2 weeks)
1 - 8 of 8 Posts
