1999 White STS Z-Rated Massage seats 140k original
i need to remove my door panel , and i dont wanna break anything
any tips would help!
99 STS, White Diamond
The screws (front and rear doors) are in two locations. Remove the little plastic piece behind the door lever you use to open the door. Bend up the little flap behind the handhold that you use to close the door. #3 Phillips screws--do not use smaller.
2006 STS V Tango int
He ment three screws typo, and on the front 2 doors than another one on the very bottom back corner of the panel #2 philips, after all the screws are removed the rest is just clips so carefully pull the panel off
Discussion Starter · #4 ·
So 1 on the bottom. 1 behind the door handle. 2 behind the handle u use to close the door!!
Thanks guys! Appreciate it!
