2023 CT5-V RWD / 2020 XT6 Sport / 2024 Lyriq AWD (reserved)
If so, what's your power source, did you do front and rear, and what model dashcam did you go with?
Thanks in advance.
Thanks in advance.
The surround vision recorder on mine doesn't record while the vehicle is in motion. Does yours?I thought about it, but the surround vision recorder does a nice enough job and it only needed a $15 SD card. My dad bought one of the GM affiliated dash cams for his '20 Sierra though and likes it. I'll try to get the name
Yes mine doesThe surround vision recorder on mine doesn't record while the vehicle is in motion. Does yours?
Thanks. I will try again today. I know that the 2020s had some bad video recorder modules so hopefully mine isn't one of those.Yes mine does
I had the surround camera issue but once that was resolved it works 100% of the time. Got a 128GB SD card in it with no issuesThanks. I will try again today. I know that the 2020s had some bad video recorder modules so hopefully mine isn't one of those.
Am using a Fat32 32GB Class 10 max endurance. Didn't know we could go bigger - not that we need to. Good to know.I had the surround camera issue but once that was resolved it works 100% of the time. Got a 128GB SD card in it with no issues
Yeah, there is some free program I used to format it to FAT32, but all the other specs match what the manual calls for. Just wanted a larger backlog just in caseAm using a Fat32 32GB Class 10 max endurance. Didn't know we could go bigger - not that we need to. Good to know.
It is called "guiformat" if you ever decide to go largerYeah, there is some free program I used to format it to FAT32, but all the other specs match what the manual calls for. Just wanted a larger backlog just in case
