2000 Seville STS
This happened once before but the period that it was "off" for was only brief...now it won't return...anyone ever see this problem? The heater controls are also afected....I've got no response there either.
53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV
Were you performing any service when this happened, or did it one day just stop working?
Watching the Watchers
i had this happen once as well, it told me the outside temp was 140 degress then went dead, turned car off and turned back on and it was fine. looks like you may still be under warranty, so im sure the dealer can fix it for you.
2000 Seville STS
Discussion Starter · #4 ·
Update: I pulled the fuse, it was ok so I returned it to the fuse box and Voila!! The cluster is now fully operational. I plan on returning it to the dealer because I don't understand this and if there is a future problem where I don't get so lucky, I want this documented. Maybe it just needed to be reset after the brief power failure? Anyway....thanks for your concern
