1 - 2 of 2 Posts
2000 DHS
I have searched the forum and found a little info but not enough.
Here's my problem;
Our 2000 DHS sunroof leaks occasionaly. After reading posts I'm pretty sure the passenger front drain tube is clogged. I've tried running grass trimmer string down the tube but the string only goes so far. I tried blowing compressed air through the tube but I can't find the end of it! I've jacked up the car, peeled back the inner fender. Where does the tube exit?
Very frustrated with this. Thanks for the help.
2000 DHS
Discussion Starter #2
I guess I'll answer my own post. Finally figured it out. The drain tube exits inside the inner fender. You have to unscrew the lowest plastic mount and pry the plastic back to see it. Mine was pinched...all by itself I guess. What a pain.
1 - 2 of 2 Posts
