2002 ESV
2002 Escalade
My SSS light is on and was told by the previous owner that the dealer said it was the auto level suspension. Now with snow on the ground, I have no traction control and I don’t think my AWD is working either. My main goal is to get traction control and AWD working.
Is there a fix for this (like removing a fuse)? Would these other symptoms indicate the steering wheel sensor? Or do I need to fix the suspension to get my traction control and AWD back?
2002 ESV
2002 Escalade
The vehicle has its own built-in trouble code scanner/memory system.
Have the car scanned at a parts shop. Use this link to further define any found diagnostic trouble codes (DTC) and post the results here.
Thanks. I’ve had one shop tell me it was a C0207 code which is steering wheel position sensor. I had another shop tell me it was air ride suspension. And another shop tell me it’s because the check engine light is on due to leak in the manifold gasket. So I was looking for some advice maybe someone who had had similar problems.
