Since mid March, my car has had intermittent low steering boost when stationary. No problem once rolling, even at the lowest speed. Yesterday, I had it back at the dealer for their third attempt at aligning the steering wheel correctly, and the boost completely gave out. They wanted to keep the car to diagnose, I needed to get home. This failure is not the intermittent like before. ZERO boost, at any speed. I'm sure that being at the dealer was just a coincidence. So, it's now time to troubleshoot and fix it.
I see there are LOTS of threads with this issue. Causes mentioned include bad battery, failed pump, chafed wiring, low fluid (and probably more that I am missing). I have looked at the wiring that passes over the front of the drivers' lower A arm. It is fine, no rubbing. Pump fluid level is in between cold and hot. No noise from pump. Alternator is not making the death whine. When I checked things yesterday in the garage, it looked like the HIDs were not turning when I was cranking the wheel around.
I can't check ProDemand today, I'm at home for a couple days. I will be back at work on Monday. In the meantime, does anyone have any thoughts for me on causes/fixes?
