2001 SLS
I've already tried seaching for threads about this issue but haven't been very sucessful. My new-to-me '01 SLS only came with one key and no remotes. I would like to have working keyless remotes but don't if I can just buy them and program them to my car. I've pulled a bunch of the carpet out of the trunk and have not been able to find the RKE module. Or any connectors with 2 purple, 1 orange, and 1 black wire. I pulled the tray that has a few other modules, but it's not there. And my trunk area looks different than those in all the pictures I've found.
So, am I looking for the wrong description? Wrong location? Does my car simply not have that option? According to the RPO, it does not...
If that is in fact the case, what would it take to add it?
99 STS, White Diamond
The RKE module is in the roof of the trunk very near the trunk light and it is in EVERY Seville--not an option.
I must ask why you're pulling carpet and wires to find the module when you have no remotes?
Remotes are cheap on ebay and reasonable new. The remotes MUST however be programmed using a Tech II. No other way.
2006 STS V Tango int
Yea remotes are 20$ at the MOST and then they just need to be programmed with a tech II for about 30$ so you in 50$ for keyless entry/ trunk pop and gas pop, plus it arms the alarm each time it locks the car
2001 SLS
Discussion Starter · #4 ·
There is an RPO code for keyless entry, my car does not have that code. So I went to find the module, it only takes a few minutes to pull carpet, as every thing I've come across said the module should be where I looked. Found numerous threads, with pictures, saying that if you're not sure if your car has keyless to look for the module. I'm not going to spend money on a remote until I know that it will work with my car. I'm not taking that gamble.
Premium Member
17 XTS Platinum V-Sport; 17 Buick Envision AWD Turbo; 10 Lincoln MKS AWD Twin Turbo
You have remote.
Every cadillac 2000+ has remote entry, so you have it unless someone or the dealer removed it
