Hey guys:
Listen, I know the procedure all to well now about how to clean the fogging front head light lenses.
HOWEVER :rant2:
I have HID lamps. When I go to remove the headlamps. there are two wires attached. One has a rather large harness which easily comes off. However, there is another single thick wire which goes through the back of the lamp, and goes directly to the HID bulb. The other end seems to come from a ballast.
My question is this....
1) How can you remove the lamp without being able to remove this wire???
2) Then assuming I get help here with that issue, you REMOVE ALL THE BULBS from the entire headlamp right.....FIVE OF THEM including the HID bulb.
Is that correct???????
Then put the fluid in......but then I am not certain where you allow it to drain??
Do you leave them off for a day or so to dry before putting them back together???
Thanks for the help guys....I know sometimes my questions can be rather elementary.......but it is what it is lol
thanks again
If it has tits or tires it needs to be serviced. :alchi:
HOWEVER :rant2:
thanks again
