Hey guys,
Im getting some subs soon and was just wondering if there was an amp in my 2003 base cts not the bose edition. I cant seem to find it:)
2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
in the trunk on the driver's side...that is where it should be...bose system or not
06 CTS Sport/Luxury package
To add on to txbest, you'll have to take the rug away from the side to get at it. Also, here are the color codes for the wires. Yes, believe it or not. The factory sub has dual coils. The A7, A8, A9 and A10. Are the pins they are located in on the connection harness. It's Connector C3 and it should be LT blue color connector.
A7 D-BU/WH Rear Subwoofer Speaker Coil 1 Output (+)
A8 L-GN/BK Rear Subwoofer Speaker Coil 1 Output (-)
A9 D-GN Rear Subwoofer Speaker Coil 2 Output (+)
A10 L-BU/BK Rear Subwoofer Speaker Coil 2 Output (-)
KOT
Cadillac CTS
The amp in my 03 was under the rear deck cover, mounted on top inside the cab. The amp is not big enuf to push any subs worth mentioning, so I hope you werent getting your hopes up! I just ran an inverter and hooked up my own amp and then built a custom sub and hung it up where the stock sub sat, just from the bottom. It sounds so much better now and still doesn't take up any more room in the trunk than the stock woofer did.
2003 CTS
Just replaced my 4 door speakers and the owner of Sight -n- Sound said if I add an an aftermarket woofer I would also need to replace my amp as the one in my 03 (not a Bose System) would not be strong enough
