1 - 10 of 10 Posts
2004 CTS-V
I did this alternative fix recently, and upon doing some searching (not very deep, I'll admit) I can't find that anyone else has mentioned it. It's essentially putting the load resistor on the rear turn signal circuit rather than the front.
Anyone who has done minimal research on LED conversions for our DRL/TS knows that hyper flash must be addressed. This has typically (to my knowledge) been addressed in one of two ways. One less used way is to crack open the flasher module itself and disable the hyper flash. The second is to attach load resistors to the circuit between the module and the new bulb.
Load resistors are a much easier option, but have the drawback of getting hot. This has required the load resistors to be mounted on a metal fixture (preferably in a place with air flow and away from anything you value). This is because our cars use the same bulb filaments for TS and DRL, and that means current is almost always going through the resistor, making it hot. But since the hyper flash is essentially "seeing" the resistance in the entire flasher circuit, it really doesn't matter where in the circuit the extra current flows. As such, I put the load resistors on the rear turn signals. I still mounted them on a metal surface to be sure though.
This fixes the hyper flash and, in theory, the hot resistor problem. Since the only time the load resistor has current passing through it is when the bulb for the turn signal is on (which is not very much of the time) it does not get hot. I suppose technically it would warm up if one sat with the turn signal on for an extended period of time or had to have hazards on for a while. I was concerned that the resistor (providing what is essentially a current shunt) may make the rear signal look sickly, but it does not.
I've had the car like this for a while now and it works perfectly.
Has anyone else done it this way?
2004 CTS-V
I can't vouch for when LEDs are used on the rear. I may invest in a rear set to see. Regardless, two sets on the rear would likely work unless they shunted too much current from the LED.
DTS
This fix did not work. The resistor apparently needs to be placed in the circuit next to the front led bulbs. I wired the resistor in parallel with the positive for the flash and the ground. I also wired the DRL positive cable into the resistor with the flash positive and the other to ground. All for no joy.
2007 CTS V, 1 7/8" Kooks, Magnaflow Exhaust w/ X pipe
The original post is absolutely true. You CAN install the load resistor at the rear turn signal and it WILL correct hyperflash. I did this and it worked perfectly. As for adding rear leds on top of fronts, you would need to then add an additional load resistor OR remove the previously installed one and replace with a larger load resistor. The turn signal circuit looks at total system resistance rather than individual bulb resistance so changing the resistance in the circuit will fix the hyperflash problem.
1989 Allante
Jakaround: Thank you for this info! I have a DTS and after replacing front turns with LED, I'm in hyperflash mode. After the major PITA that is front headlight removal in the DTS, adding resistors to rear sounds like the path of least resistance (pun fully intended).
Question: did you add LED to rear as well? While I don't think (theoretically) it would make a difference, I wanted to confirm before adding the resistors.
Also, where did you mount for heat issues?
1 - 10 of 10 Posts
