Alldatadiy usefulness
958 views 8 replies 6 participants last post by  naiku
I'm trying to find a repair manual to point me in the right direction to replace the control arms, used to use Haynes manuals, but I'm sure there are better options now.
Lots of little recommend alldatadiy (funny that a year or two ago, the yearly price little say it's $15, now it's $60). Anyway, how useful is the alldatadiy info? Looking at an example they posted, it's really vague ...
"Remove the front lower link nut and bolt from the knuckle side and the adjusting bolt and nut from the suspension member side using power tools."
That's for removing a lower link on a Nissan, it's the example they have available. While that tells me what to remove, there's no mention of what size nut or bolt. One small picture, just not a lot of info. Is that normal? I mean I could figure out removing a nut and bolt without spending money!
A 2nd example, removing a control arm from a Ford has more detail in terms of illustrations, but still zero info on bolt or nut sizes. Maybe there's too many different options to list those, but it's a surprising thing to be omitted entirely.
Just curious if that's normal, or if I pay for a subscription, is there more actual info available.
Thanks.
#2 ·
Alldatadiy.com is the online versions of the real GM/Cadillac/Helm service and repair manuals, where available for online viewing. Your 2012 should be supported. For price comparisons with the same issue paper hard copies look at www.helminc.com.
Regardless of the source - GM Helm, Haynes, Alldata - you won't find many actual bolt sizes but if you dig into the specs and diagnostics sections in Alldata you get to some sizes and all torque values.
Alldata also incorporates tables of DTC - Diagnostic Trouble Code - links. Click on a code and you get pages of system descriptions and repair/troubleshooting procedures.
The multi-year deals are well worth the price. I have 3 subscriptions for 3 different vehicles - the STS, an Explorer, and 2 F-150s.
#7 ·
I use Chilton Manual, for FREE on my computer on my desk from the Library.
I can go on and put in the make and model year, and then pick what I want to fix. Like the control arm.
You don't have info like AWD or upper or lower so I don't know what you are doing.
Now please remember these manuals are NOT trying to teach you how to become a good mechanic.
They are to inform a good mechanic on how to replace or diagnose a car.
It will show you the torque value of the fastener but it's on another page.
see how to use the repair manual.
#9 ·
Sounds like overall it will be worth the subscription then, I may start with a month and go from there.
AWD, front, upper and lower. Passenger side front is creaking, can't if it is lower or upper, but with 125k on it, I figure if I am replacing one, I may as well do both sides upper and lower.
