i have a 2000 deville.
I had a problem with my window regulator. So my window won't go down. I screwed on the regulator to where my window won't go down.
In short i disconnected the harness that connect to the window motor.
I don't know if this has anything to do with it but i thought ill mention it.
Well my lighters dont work , none of them. I checked the 30 amp relay in bottom of back seat. I switched it with window rear defogger relay ( which i know works). and nothing.
any ideas?
thanks in advance
2002 Cadillac Deville (Base)
I thought there was a few more fuses for the cigar lighters, plus I believe there was a service bulletin about cigar elements shorting out to ground, you had to replace the whole assembly with a new one.
i'll check for fuses under the hood.
does anyone know where i can get the circuit for the cigar lighter?
thank you
Deville
i burned out the cigar fuse on my 02 deville and just changed it under the hood. its a lil 20 amp yellow fuse.. its the box right in front on the passenger side.
thanks guys it was indeed both fuses under the hood, im not sure how i blew them out though, i normally use it for charging my phone
