there is not... On the alignment machine you enter the vehicle it doesn't give you an option for wheel sizejimmy88 said:Can anyone tell me if there are different alignment specs for an 06 base with and without 20 inch wheels?
Not sure but I wonder if it's a sensor limitation on the gear they usejimmy88 said:Thats the affirmation i was looking for,i wonder why it say except 20 inch wheels on the top of the printout
I don't understand it myself why they would be different, but at the alignment shop I use they have two options, 17" and 20" specs.there is not... On the alignment machine you enter the vehicle it doesn't give you an option for wheel size
Mine is the same at the shop I had mine donewake said:I don't understand it myself why they would be different, but at the alignment shop I use they have two options, 17" and 20" specs.
It would work under the platanium profilejimmy88 said:Weird stuff i have an 06 base with oem 20, i wish i knew a certified gm tech so they could look up the difference.
