The rear tires on the ATS were worn, so I bought the same BF Goodrich that were on it -which also match the front, but are larger staggered, per OEM.
The front tires have great tread depth, so I didn’t replace them. But, I noticed that the inside of both fronts have a little more wear, so I am going to get a 4 wheel alignment-right?
There are about 74k miles on it. I also have a slow leak on one front tire. I put 60lbs in it, jacked it up and rotated it, using soapy water to look for the leak. I didn’t see any nails etc. or bubbles.
Also checked the valve stem and it didn’t blow any bubbles.
I’ll have to pull it off and check for a bead leak -but also wondered if the rims get cracked very often, like the ones on my Z 06?
