Air Ride/Suspension Problems
1 reading
13K views 3 replies 3 participants last post by  frankcbyrd
I was a "gullible" owner of a 2004 Cadillac Escalade. I just crossed over 226,000 miles on the same engine. I noticed that my ride had gotten rougher over the past couple of years so I started to take a closer look at my suspension. I was one of those guys that always took his vehicle to the "Dealer" until I found a local garage that performed any repair that I needed at nearly half the price. My local garage owner told me a few horror stories relating to his "working for the man" that made me want to hate all "Dealer" Service Departments. Some of their tactics he told me about would surprise you. Maybe. Unfortunately, my local garage had to close since the city would not renew their lease, which is in a prime location that the city is currently expanding/upgrading with higher paying clients (that's a whole other story - don't get me started). I will truly miss his services of the past 12 years.
Anyway, my air ride compressor failed over the summer. I went on You-tube and found that changing out the compressor was quite simple, so I ordered one and replaced it myself. The compressor worked great but the Escalade didn't rise or fall when the compressor came on. The compressor would cycle on and off at startup, and at times, continually while driving. After about one month, the new compressor finally failed. After performing some checks suggested on You-tube, I decided that I should have my air ride system checked for leaks. Since my local garage has not re-opened at a new location yet, I again had to rely on the local "Dealer' for service. I had the "Dealer" check my system for leaks. They told me that my rear shocks were leaking and had to be replaced before they could continue the test. You-tube made replacing the rear shocks look simple but I couldn't get up the nerve to try replacing them myself, so I had the "Dealer" replace the rear shocks AT A COST OF $1600.00. The "Dealer" told me with a straight face that for another $750.00 they could replace the compressor also - NOT A FREAKING CHANCE - I bought a new compressor at the local O'Reilly's for $286.00 and replaced it myself. I also replaced the compressor relay under the hood. So here is my problem: My air ride suspension continues to be INOP.
I don't get any alerts, other than "tighten fuel cap", but the new compressor cycles on and off at engine startup and occasionally while driving. I am heading out of town for Thanksgiving so I will disconnect my compressor for my trip there and back. I am currently unable to tow my trailer, and when loaded with suitcases in the back of the Escalade, I get an occasional tire rub from my 22's. My thoughts are that there is a leak, other than my rear shocks, that my "Dealer" may already know about but is waiting for me to come back to get fixed for some crazy price. I just don't know enough about my Escalade (mechanically) to figure out this problem myself. I don't mind paying to have this problem fixed, but I don't want to replace parts unnecessarily just because the "Dealer" wants me to replace them either. How do I check my air ride system for leaks?
By the way; that "tighten fuel cap" error is another topic for another thread.
#2 ·
How do your air lines from the shocks to the compressor look? Assuming the new shocks the dealer put in are not defective and you mention the compressor does run on start up, you may have air lines that are leaking and need to be replaced. When I replaced my shocks and compressor I also replaced the air lines to eliminate any chance of the system not working. They are pretty cheap and dare I say, Doorman offers a set on Amazon. If I recall correctly, they took less than an hour to install. Probably could do it much faster now that I know what I am doing. I recently did the Chicago to Orlando road trip with both a trailer cargo tray with 7 suitcases and a huge Thule roof box why a ton of other crap not to mention 5 people. The self leveling suspension worked great!
Good Luck
#3 ·
Unless you just have to keep the air ride, I'd ditch the system altogether, and install regular shocks. There are a couple of Bilstein install threads in this forum. Disconnect the air connections from the shocks, replace the shocks. Unplug the battery, disconnect the RTD fuse in engine bay. Reconnect battery. Never worry about air ride again. Bilstein shocks were about $240 for the entire set. I imagine labor would probably be about the same.
#4 ·
Thanks Rivelite and tokuzumi for your replies. MY AIR SYSTEM IS FIXED! On my way to Georgia, I stopped in South Carolina to have my mechanic brother-in-law to take a look at my air system. He diagnosed the problem in less than 10 minutes. Apparently, the air connector on the compressor had vibrated itself loose from the nipple. Looks like I failed to make sure that the clip was on tightly and it came off. I FEEL LIKE SUCH AN IDIOT. The air system is working fine now. I take back everything I said about my "Dealer" Service Center.
