1 - 8 of 8 Posts
1999 Deville
Hello I own a 1999 Cadillac Deville and I’m wondering why I only get air through the defroster and not the actual vents. A while back I had air flow blowing through the vents but it stopped. I switched one blend door actuator on the passenger side under the dash but didn’t seem to fix it. Please help I don’t know if there’s another one I need to switch
2002 Deville and 2009 DTS
I am not sure about the 1999, but I think there are 3 blend doors.
1 on the passenger side and 2 on the driver side.
The pre-2000 Deville's get air from the dash vent ONLY when in the A/C mode.
Heat comes from the floor vents or windshield vents.
Check your owners manual.
1999 Deville
I don’t have the owners manual but I haven’t found anything that it only blows from the defroster or floor vents.
So what your saying is that it’s normal for it to come out from only those or should I look into the second actuator
There is at 2nd actuator... look at the pictures I attached previously.
Look at the parts in red circles...# 5 and #25
your 1999 Deville still has the hybrid system -
electric actuators control the TEMPERATURE -
vacuum motors control MODE - WHERE the air blows from -
also - this is a fully automatic climate control system - except DEFROST -
meaning it was designed for you to simply set the desired cabin temperature
and the system would control the airflow to maintain that set temp -
depending on AMBIENT temperature -
HEAT is discharged from the floor vents -
AMBIENT and COOLED air is discharged through the center vents -
HOWEVER - if there is a vacuum leak -
the MODE will DEFAULT to the DEFROSTER position -
SO - if you select a higher than ambient temperature -
BUT you only get heat from the defroster -
either you have a vacuum leak - OR the vacuum motor controlling MODE is defective -
1 - 8 of 8 Posts
