1 - 9 of 9 Posts
2001 deville
I get cold air on passenger side and warm air on driver side. I can not switch mode from floor, defrost.. air only blows out the vents does not make clicking noise when I switch threw the different modes been reading a few different threads about this situation not sure witch actuator I need to replace or do I need to replace the door as well sounds like it's a very difficult job to do any advice or tips would be greatly appreciated
The temperature problem sounds like you are low on refrigerant.
The mode problem is most likely an actuator. Pull your DTC's. There should be a code for it.
like Ranger suggested -
start by pulling codes -
if you have any codes -
post the code number -
ALONG WITH THE CODE DEFINITION -
go here for code definitions -
http://www.cadillacfaq.com/faq/answers/dtccode.html#bod
all the actuators are "monitored" -
meaning if they fail to respond properly -
a fault code will be set -
MIX DOOR ACTUATORS control cabin temperature -
#1 is the DRIVER side -
#2 is PASSENGER SIDE -
#3 is BACK SEAT -
NOTE - 99.999999999% of Devilles
will report having the B0428 and/or B0429 codes -
the #2 actuator also controls the rear seat mix door -
MODE DOOR ACTUATOR -controls where the air blows from -
CLASSIC symptom of a low freon charge -
with the AC set to 60* - medium speed fan -
locate the two metal evaporator lines going through the firewall -
feel the temperature of the two lines -
they should both be equally - very cold -
if you notice any difference between the two -
you are low on freon -
DO NOT JUST ADD FREON -
and don't be tempted with an el-cheapo refill can with the built-in gauge -
they are junk -
lets DIAGNOSE the problem first -
THEN we can figure out a solution -
2001 deville
I stopped by autozone today they check for codes but I did not have any codes show up. I order some gauges online once I receive them I'll check my pressures what should my high side pressure be? according to the junky hose that came with the 134a can my low side is around 35-40psig
AutoZones scan tool will only pull P codes, your issue would trigger B codes. Your car has a scan tool built in. Go to the top of the FWD Deville/Fleetwood page and click on the sticky thread on how to pull DTCs.
Ballpark pressures are 30-35 on the low side.
2 - 2.5 times the ambient temperature on the high side.
Also check the A/C inlet and outlet pipes on the firewall. They should both be cold and the same temperature.
Hand check will work, but an IR thermometer would be even better.
2001 deville
I check my codes I got a lot of codes but these are the ones that go with my ac or I'm not sure what they mean
B0248-mode door inoperative
B1009-eeprom check sum error?
B1004- keep alive memory (kam)?
The last two are probably just from pulling battery power.
The first one means just what it says. Probably a failed mode door actuator. Which is why you "can not switch mode from floor, defrost".
as I said in post #3 -
MODE door controls WHERE the air blows from -
floor - center vents - or defrost -
but it has nothing to do with your temperature problem -
1 - 9 of 9 Posts
