When the car is accelerating to and staying at speeds above 75mph, does that have a negative affect on the a/c system or can it continue to run undamaged?
97 Deville
Well on my 97 Deville when i have the A/C turned on and i'm getting onto the interstate and i floor it so i don't get ran over by the semi's going from about 30-60 Mph the A/C plunges a little but once it gets to about 60 Mph it operates normal without anymore plunges. But i wouldn't say that it has a negative affect on the car. An example of what my A/C does it feels like if it goes from Auto to Low.
The compressor is disabled at WOT on the assumption that you want max available power. Other than that, I am not sure I understand the question.
2003 STS w/BoseNav, 1993 Deville, 1985 Deville
I'm also not sure what you're asking.
Why do you suspect that running the car over 75 or accelerating hard will damage the AC?
77 CDV, 06 DTS III, 69 FWB
Since the compressor is "on-demand" and not continuous, I don't see that the vehicle's speed is relevant to AC operation. I've cruised my ETC for hours on end at 80+ with the AC on and had no problems.
