1 - 9 of 9 Posts
2015 CTS
Discussion Starter · #6 ·
104,000 miles just wondering is there a relay or sensor that tells it to cycle just figure it has to be something like that cause it just runs all the time and I'm not low on R134
CTS 03
There must be a sensor in the vent that tells the compresor when to cycle on and off, I noticed when I set the A/C to 60, the compressor stays on more. Try setting your temp to the highest, 85 or 90 degrees and see if it cycles. BTW, you seem confident that you are not low on R134, did someone check if for you?
1 - 9 of 9 Posts
