Hi guys, I have a 2001 SLS with just over 100k miles. Love the car, we don't use it a lot. The a/c fan will go on for about 10-20 seconds then cut out. I turn the system off, wait a minute , then turn it on again and the same thing happens. What appears to be the problem? This is a Florida car. Thanks in Advance
Ed
· Master of the Dark Art of Diagnostics
Re: Air cindition fan problem 2001 SLS
Ed
could be a bad ground -
located behind the passenger side kick panel -
but - most likely the blower motor is simply worn out -
I recommend the FOUR SEASONS 75749 -
a direct fit replacement ~ $43 - with shipping -
http://www.amazon.com/Four-Seasons-...automotive&vehicleId=1&vehicleType=automotive
Discussion Starter · #6 ·
Thanks guys... I took the glove box out and disconnected the lead to the blower motor. tried the new one and neither worked. Went thru the fuses and everything checked out. I started moving the wiring harnesses around the fan and the blower started to work. It was a loose wiring coupling a few inches away from the fan motor. Thanks for the assit. I appreciate the input. Happy Easter
Ed
