ok, so last night when switching from radio to cdp, I noticed the power antenna on my car was getting stuck, it would stop going up/down and make this clicking sound
I read in the manual, that, to clean the antenna, just get some mineral spirits on a rage, and clean the whole antenna
I did that
it cleaned everythying off very well.
The antenna still dosn't work correctly, at first, it would go completly up/down like it should, but now it gets tuck halfway down.... (I am outside the car, have the remote for my cdp in my hand and switch between tuner/cd to make antenna go up/down.
I noticed when the antenna is at the very top, and when it tried to go down, the mechanism can't catch, and it will just stay at the top, I hear the clicking sound, and then it stops.
So now it will go up, when I turn the radio off, it will go down, but I need to help it atfirst, is will go about halfway and stop
ok, this is the conclusion I have, it keeps track of how long it takes to go all the way up, so when it is time to go down, it will run the motor that long. Well, when it is only halfway down, and I make it go up, it goes fine, so when I make it go down, it will go down (sometimes i have to push it at first a little) then about halfway, it will stop (becuase that is the distance it went going up)
in the manual, it siad to gently push the antenna in, I can't do that, as whatever is in there is holding it from going down, and when I remove the side panel in the trunk, I can see the whole mechanism move as I try to push it down...so that's not going down manually
Can anyone help? is there some kind of a reset? my main questions are, how do I get it all the way down again, and when at the very top, how do I get it to "grip" on it's own?
like I said, it started lastnight, when it would go up, it would get stuck a little, and the antenna would slow up, and the motor would make this clicking sound, now it is only halfway up or all the way up, it will not go all the way down at all.
Any help would be great, sorry for this being soo long, I was trying to describe it best I could....
.....it is times like this when I don't like having a car with all these power features, becuase when they don't work, I get pissed off
I did that
