41 - 59 of 59 Posts
2016 CTS 3.6 Premium RWD, 2012 CTS Coupe Premium RWD (sold)
Where are the controls for the heated/ventilated seats? And controls for the rear HVAC (for premium models)?
2014 Cadillac CTS
Discussion Starter #42
They are built into the touch screen menu on the bottom. When you press it the screen expands and gives you more options for HVAC.
Sent from my SM-N950U using Tapatalk
2014 Cadillac CTS
Discussion Starter #45
I know on mine it was labeled and came with a single wire that had an RCA on one end that then plugged in to the rear camera plug
Can you send me a photo of your harnesses when you have time if it's not too difficult?
I want to make sure I got everything I was supposed too.
2014 Cadillac CTS
Discussion Starter #46
Few updates...the only thing I haven't got to work is the backup camera, and when I click on the console button it show "no signal" for some reason. Same thing with the video button when I click on it. It has a Fast and Furious trailer downloaded from factory that won't play. I hear sound but it says no signal for video also. I'm working with the seller but they aren't very good at answering simple questions half the time.
2010 cts wagon 3.6 awd
Not sure when I would tear the dash back apart. Look for a connector with a single RCA that says backup camera, I think it was brown. Then find the plug that matches it on the factory end
So when I load and try to connect to the elm it asks permission to turn on Bluetooth. When I do I just sits there. Am I doing something wrong?
2014 Cadillac CTS
Discussion Starter #49
Ok so after starting the ignition the backup camera seems to work while the unit is loading up. Nice surprise, but once the head unit loads up to the home screen the backup camera doesn't function. Here's a quick video...any ideas ?
https://youtu.be/HcHcR5VgMjc
2014 Cadillac CTS
Discussion Starter #50
Yeah mine didn't come with that yellow RCA, I asked ....and the seller said mine wasn't supposed to based on my unit and car model??
That is strange, what if you manually go into camera and pull it up. If I’m not mistaken there is a camera tab across the top. If that’s the case it may be something in one of the advanced settings. I thought I remember seeing something for camera auto on reverse.
2014 Cadillac CTS
Discussion Starter #52
That's what I'm thinking too, when I turned OFF video in motion in settings the video button now works perfect. Before I could only hear audio when a video was playing... Very strange. I'm going to look in settings again and follow back up
Just checking back to see if you found a fix for the backup camera. I'm considering replacing the touch screen on mine, but would rather find something aftermarket if it works.
2014 cts
now that a few of you have had this for sometime now any complaints? was there a fix for the back up camera? can you still use valet mode?
2015 CTS4
Check the voltage going to the backup camera from the unit. If the voltage from the unit isn't at least 12 volts the camera may not turn on. In my older BMW, I installed a backup camera and of course wired the power lead into the reverse lights +lead. Could not get it to work. I finally measured the voltage at the reverse light and found it was 11 volts. I ended up using a relay where the signal from the unit was the input to the relay and hooked the relay directly to the +lead on the battery and then to the camera.
2014 cts
i finally got my radio in and started to install it. my steering wheel controls were working but once i plugged in the t-harness they stopped but the reverse camera works. i cannot get the unit to play a movie even in park and cannot get any sound from my car speakers using youtube. any suggestions?
2014 cts
idk if anyone else is having these problems but let me know.
1.the only way to get sound to play from the radio is to run the aux cable from the back of the unit into the armrest and plug it into your aux port.
2.while trying to reverse the backup camera will not turn on while you have the aux selected.
3.the factory camera picture is too small for the screen so about 1/4 of the screen is just black
4.there are 2 sets of parking guide lines one from the factory and one from the unit itself
5.noone can hear me when i use the unit to make a call
6.there is no choice for a cts so on the home page you have to choose between 5 other different cadillacs
7. when you customize the unit by using nova launcher it doesn't launch on startup so you have to find the app and start it yourself
41 - 59 of 59 Posts
