1 - 20 of 22 Posts
:banghead: ok here's the thing i have an indash monitor (Pioneer AVH-6400CD) that i want to install on my deville, but i do like the way the music sounds now (7 speakers and (im guessing) an oem amplifier), what i want to do is install the monitor but since the oem radio connects to an amplifier will this be a problem ? for example can i just wire the radio up and then from the radio it would go to the amp and from amp to the speakers? or would i have to end up some how making 4 channels into 7 channels? because i want all speakers to sound.
the reason why i ask is because i had heard a rumor that when you connect an aftermarket radio to an oem amp , you end up getting a slight noise in the background, which is something i dont want.. is this true ?
i also have another issue , i have 6 brand new 6 1/2 inch component speakers that i want to replace with the oem speakers on the deville , now i do know that the oem speakers are 5 1/4 but anyone have any idea if the 6 1/2 speakers will fit , because i honestly cant just go and return them since i bought them a while ago (on ebay) , i am going to connect them if they do fit to the oem amp, any suggestions ?
and last question is, in order to install the aftermarket radio i have to purchase the aftermarket kit (the black plastic trim panel that goes around the radio) now if i install it will i end up losing the oem wood trim it has now or will that just go over the aftermarket kit ? :banghead:
02 Seville STS
Does it have the bose system? If it isn't bose then I don't believe it is amplified. If it isn't amplified then you will have no problem connecting the new radio to your stock speakers. Since there is only 4 channels, but 6 speakers total. Also to my knowledge, not that it is that great, but I think it's 5.25 components up front and 6x9's in the rear deck. When I had my doors ripped apart it looked like it would be a pita to install 6.5's up front. Not that it couldn't be done, but it looks like some work. I believe you can get adapter plates to fit in the 6x9 spot if your set on using the 6.5's.
well it doesnt say bose anywhere but the car does have the cd and tape deck , and it does have 7 speakers, and sounds actually pretty good, the reason why i didnt think it would have 6x9's in the back is because when i checked at crutchfield, thats the fitments it gave me 5.25 all around and in the rear 6.5's even though my friend has the same car same yr with a regular tape deck and 6x9's in the back , so now im really not sure..
This system might be the "active audio" that I am trying to track down. Ok, where are the speakers located?
2- 6x9's in the rear deck.
4- 5.25's in the doors?
Where is the 7th speaker?
Discussion Starter · #6 ·
yup thats exactly what it is , its the "active audio" 4-5.25 in the doors and i guess 2-6x9 in the back , but i think the seventh one is on the dashboard, right on the top, where the vent is, so it appears to me , now does the "active audio" come with an oem amp ?
because for the yr the car is the music sounds pretty dam good and loud , and its all orginal from what i know..
I second that. I can't even find any information about the active audio, much less an adapter. I am not sure if the speakers are Bose, so I wouldn't reccomend using them until you know what OHM they operate at. If you can tell me the OHMS, I can tell you if you can use them with an aftermarket amp. They might say on the back what they are rated for.
Discussion Starter · #11 ·
yea but rewiring is a pain in the asss, what im thinking of doing is just removing the speakers and putting in newer speakers (blaupunkt components in the doors) pioneer 4x6 on the dash and 6x9 3 ways on the rear , but now im having another problem, my cousin works at bestbuy so i told him to get me the wire harnes for the radio that way i i dont have to cut them out but seems im going to have to because aparently theres 2 wire harness's i can use but neither of them work , i checked on crutchfield and it pulls up a white one which doesnt work at all, and then at bestbuy i bought another one they had which was a blue one and didnt work at all either..
and then the guy at bestbuy told me to use the wire harness i would have to run wires all the way from the rear to the front which makes nooooo sense at all , why would i go through all that trouble just to use a wire harness, for that i'll just cut in the front and wire it up from there , im going to probably end up selling the OEM cd player anyways..
but yea anyways this thing is begining to be a mess lol, but as far as me using the bose speakers or active audio no i will not i doubt they might be able to hang with an aftermarket amp , i rather just replace them because i probably will get better quality out of the newer ones considering the 10 yr difference on them..
well guys im open to any suggestions lol
Banned
2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
my opinion is to ditch the stock harness completely your only going to cause yourself more trouble and more time trying to use it and figure out what wire does what and remember all the wires in that harness for speaker output go TO YOUR AMP b4 they go to the speakers so you cant just cut the plug and direct connect it. You going to have to run new speaker wires for the car. I know it will be time consuming and probably not the funnest job but it is the easiest way to do this. I had a Bose System in my 97 ETC and i had to rewire it completely. It wasnt that bad really kinda fun takin apart the cars entire interior.
Discussion Starter · #13 ·
yea i found out today im going to literally have to rewire the car , i already bought the antenna adapter, plus the antenna extension (12 footer, which im hoping thats enough from the trunk to the dash) and the wire harness for the back ,now i have another problem, i want to use 7 speakers but i only have a 4 channel amp , is there any possible way i can use the 4 channel into a 7 channel ? because i honestly do not want to go buy another 4 channel amp just for 3 more speakers.. another thing is if i rewire the speaker wire as uppose to using the stock wires provided is it actuallyyyy that much of a difference because i honestly do not want to go through all the trouble of rewiring to the dash, all 4 panels, and the rear deck..
Banned
are the new speakers your getting really that great? why not just run 4 off the stock hu and 3 off the amp. That being said yes you can run all 7 off a 4 channel amp. you just connect more speakers to each channel. GL
Discussion Starter · #15 ·
um uh i dont get it ? u mean run all 7 to the aftermarket amp and try to run it in series or run 3 on the aftermarket amp and 4 on the oem amp ?
the speakers i plan to put is:
1-4x6 pioneer 2way
4-6.5 blaupunkt compenants (overdrive ones)
2-6x9 pioneer 3ways (the yellow ones)
what do you guys think ?
Sounds pretty good to me. What he is saying is to run 4 of the speakers off from the head unit and three off from the 4 channel amp. For example.
Run the door speakers and 2 dash speakers off from the head unit. Then run the 2 deck speakers and the center channel off from the amp. I had a similar system in my Mark VIII, only I had 8 speakers running.
Discussion Starter · #17 ·
ok sounds like a good idea but now i have a nother problem , the guy at best buy was right i actually have to run all the wiring to the front in order to install the indash monitor, any suggestions on thw wiring from the trunk to the dash ? or if there is a kit that is available?
Just a note - You can tell if you have an active audio system if the rear doors have small speaker grils in the arm rests. If they don't - you probably dont have an amp - the origional factory active audio is 11 speakers - two in each door - one in the armrest, and one in the lower door - the dash has one in the center, and two in the rear shelf. The Amp is located in the trunk - remove the panel covering the back seat, and you will find it, along with the ride conputer - security system, keyless entry, etc.
If it has a 5 band Equalizer, and no speakers in the rear doors, then it is a seven speaker system, on four ouputs - two in each front door, two on the rear shelf, and one in the dash. I don't think that type of system has an amp. It sounds like you have the higher-end system. I replaced the 7 speaker system in my 95 deville with a Pioneer DVD/GPS Touchscreen, and used the factory speakers with no problems. While in my Seville (a 94) I had to do the whole system, as it had a built in amp. In the end - I reused some of the existing wiring in the Seville, and re-ended with new conectors. I did however inistall a new aftermarket amp in the trunk in pleace of the old one. This made use of the existing factory wiring easier.
Hope that helps a little.
1 - 20 of 22 Posts
