Aftermarket head unit install kit in 91 RWD Fleetwood Brougham
1572 Views 1 Reply 2 Participants Last post by  90Brougham350
I will be replacing the stock Control Head Unit (Double DIN) in my 1991 RWD Fleetwood Brougham. I want to make sure I get the correct install kit so there aren't any gaps and everything will look good. Is this the correct install kit?:
http://www.circuitcity.com/ssm/Metra-GM-Custom-Installation-Kit-99-4000-/sem/rpsm/oid/44373/rpem/ccd/productDetail.do
Also, this is the Kenwood I'll be putting in:
http://www.crutchfield.com/S-jlxNUNerefm/cgi-bin/ProdView.asp?g=300&I=113KDCX789
1 - 2 of 2 Posts
You will most likely have to to a little modification. Some guys have modified the molding piece from 93-96 Fleetwoods, but the stock molding comes in at a slight angle around the radio, so when I tried to see if my single din Blaupuknt would even fit, the radio was too wide for the molding. Ask around, good luck!
Brian
1 - 2 of 2 Posts
