1 - 20 of 20 Posts
2005 STS N* V8 1SE "Vera", 2001 Seville STS "Cassie" (Sold)
Hello all, we recently sold my wife's 2001 Seville STS and have been looking for another STS, we came across this Black 2005 STS V8 with just under 101k on it.
Went to look at the vehicle today and I was very pleasantly surprised by the vehicle, even though it is clearly the base V8 it was nearly as nicely turned out as her old fully loaded Seville. Needless to say, when we drove it, it was buttery smooth and went like a shot.
Even thought the car spent 2 years in Michigan and Pennsylvania there was negligible body rust and the brakes lines looked to be in good condition.
When I connected the OBD II reader this was the only code that showed up in the history:
Electronic device Technology Electronics Gadget Dive computer
The car's history is two previous owners, one fender bender that damaged the left front fascia, a replaced starter and battery and all factory recalls taken care of. There is also a cone air filter (my guess is due to the fender bender it was cheaper than the factory box) and the Engine cover is Red (looks factory?), which I hadn't seen before.
Since the car needs new brake pads and a wash I was able to talk the dealer down to $7000 out the door, but before I pull the trigger I'm gonna take it to the local caddy dealership for an inspection and Engine diagnostic.
What do you guys think? Should I pull the trigger on this 05 STS for $7k or this 04 Seville SLS for $4.5k? Thanks folks.
05 STS4
<img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=289761"/>
Unless the tc light was on I wouldn't worry about it.
And FYI that sts has VERY rare gm accessory tail lamps. Don't damage them.
Nope, no annunciator lights of any kind that I saw on the 'spirited' test drive.
Discussion Starter · #4 ·
Okay, I had the local Caddy dealer put the 2005 STS 1SE up on a lift, looked at it, ran a Engine diagnostic. The car came back with front daytime running lights needing to be replaced, there is a little bit of oil "wicking" up an electrical wire through the camshaft actuators, possibly a dribble from the front of the camshaft cover, and one of the cats is giving reduced performance (not an issue since I won't need to do inspections). The Caddy dealer says $1979 for all of it, which has been helpful for price negotiations, as I am more of a DIY guy, within my limits.
The mechanic said it handled very well for an 05, and didn't seem to concerned about anything he found. I got the seller down to $6750 maybe less, what do you all think?
05 STS4
Tomcat_AL200 said:
Okay, I had the local Caddy dealer put the 2005 STS 1SE up on a lift, looked at it, ran a Engine diagnostic. The car came back with front daytime running lights needing to be replaced, there is a little bit of oil "wicking" up an electrical wire through the camshaft actuators, possibly a dribble from the front of the camshaft cover, and one of the cats is giving reduced performance (not an issue since I won't need to do inspections). The Caddy dealer says $1979 for all of it, which has been helpful for price negotiations, as I am more of a DIY guy, within my limits. The mechanic said it handled very well for an 05, and didn't seem to concerned about anything he found. I got the seller down to $6750 maybe less, what do you all think?
FYI all 04-05 lh2 Northstars have 12 years 120k catalytic converter coverage.
2007 SRX4 Sport V8 Magride
Did you take it to Hendrick? I have a poor opinion of them...
I live in Norfolk and do all my own work on my 05. I can go take a look at it if you're serious enough about it.
Warranty is 12 years / 200k.
Discussion Starter · #7 ·
You are my new favorite person! What all would I need to say to redeem that bit of awesomeness.
2006 STS 1SG & 2007 STS 1SE
These cars vary a lot based on trim level & options. Most of these are not easy or cost-effective to retro-fit.
If you've driven some other differently-equipped STS's (not Seville's - a completely different car, I know., we had one, too) and this one is equipped the way you like, go for it.
If either of the above are false, I'd recommend you look around some more to be sure. But if you're in love, take it home. We love ours & have since '08.
It will come up when a Cadillac Dealer replaces your cat's due to the right code.
Discussion Starter · #9 ·
Well I would LOVE to get a 1SG with a HUD or STS-V, but the car isn't for me, its for my wife who's initial requirements were, 4 wheels, 4 doors, ATX, heat, and A/C. She grew up in NorCal driving bland I4 ricemobiles, so she has fallen in love with the build quality and feature of our shortlived Seville STS. While I might be tempted to upgrade some interior features or the aux transmission cooler, she's happy with the 1SE trim.
05 STS4
Toys can be added if you have the talent for it.
Discussion Starter · #11 ·
I'm sure the bug will bite me somewhere down the road, expect I'm going to try to pick your brain up for some of that! Lol
Discussion Starter · #13 ·
Good deal, I'll have to try 1 or 2 of those if we had to pick up the car. Wish me luck in getting them down to 6500 or less
Discussion Starter · #14 ·
We are now proud STS owners! Thank all for the advice and help, I feel like we walked, er, drove away with a solid car for $6400. Land vehicle Vehicle Car Cadillac sts Sedan
05 STS4
Tomcat_AL200 said:
Do you all have any idea what this switch does? <img src="http://www.cadillacforums.com/forums/attachment.php?attachmentid=290465"/>
Clearly aftermarket.
I suggest popping the panel and seeing where the wires go.
Maybe to a set of lights.
If you had nav I would say maybe a lock pick.
2010 STS 3.6 AWD 1SB Black Cherry
Congrats tomcat, i am envious of the photo with no snow. Up here we are sore and tired, i will be double envious if your state RMV has no front plate requirment, get rid of the mount.
05 STS4
And leave 2 even ugly holes in your front fascia...?
Discussion Starter · #19 ·
What explains why it wasn't in the manual, I will try to figure out where the hell that thing goes. And being from michigan, once I get it titled, the front plate covers coming off.
1 - 20 of 20 Posts
