I was wondering if there is a fuse for the adjustable pedals? Mine don't work at all, I read the owner's manual and it said that it only works in PARK so I tried that and nothing. I also checked the manual for the fuse diagram and it says nothing about power pedals.
Any of you have this problem?
SRX, CTS-V
I had that exact problem. I could never figure out if there was a fuse or not.
The dealer fixed mine under warranty and called it a "short" in the system. Not quite sure what he did, but it has worked since then.
I killed mine on the test drive - it also knocked out the power window switches on the passenger side....
I had my foot over the brake and partially gas when I pulled the knob toward me assuming it was a telescopic steering wheel. the loud throttle let me know what it was fast - and after I dropped them back to the floor they were out.
The dealer fixed it quickly and the salesman said that cruise control, window, and adjustable pedals were common problems with "shorts". I assume that there is a fuse he replaced.
For laughs, see if you can operate the passenger front and rear windows using only "their door switches" not yours. Then check the cruise control. They might share a fuse.
Anyway it was weird. now if someone can explain why the heck I have to remove half the front end to change a signal light I can sleep..............
2007 N* Thunder Gray/Ebony AWD/NAV/MRC
