1992 Cadillac Seville STS
I have a 1992 Seville STS that came without RKE and I't like to add the original system since I don't like aftermarket units. I'm a little confused since some sources say that most parts are interchangeable from 92 to 95 while others say that there are 92 only parts.
Will my car be prewired for RKE? If it is, do I need anything besides the receiver and remotes? Which part numbers will work for me?
Thanks in advance.
2008 SRX
Check for option code AU0 on th e RPO label under your spare cover. I thought all STS models had this. If so, buy a remote, the programming wire is next to the trunk pull down.
Thanks, I did check the RPO codes. I don't have AU0. Looks like most export cars came without RKE.
92 seville STS
Hello,
i know this thread is old, but:
did you find a solution to your Problem?
Did you find a factory module or did you use an aftermarket solution?
if so : which aftermarket RKE could you recommend?
thanks
