1 - 2 of 2 Posts
14 ATS Premium 3.6L AWD
Welcome to the forum. Using the Search Community at the top of this window will bring back a wealth of information regarding this oft discussed topic. You don't give us any indication of which trim level you have and it does make a difference. I've been successful with just plugging in an led bulb but my turn signals are not used for DRL's. In other words only one bulb "element" and two contacts are needed. For those without the blade LED DRL's it is apparently more challenging. A tour through the results of your search should save you from some of the learning experiences and maybe supply a solution worth trying. Good luck!
1 - 2 of 2 Posts
