Has anyone ran into this in the past? Is there a way to bypass the "adaptive" part and allow me to settle for old fashioned cruise control?
I've had troubles too, as the way it is programmed even if working, that if nothing sensed for a while it will go into a protective mode and force you to drive without cruise for a while until the system resets. Very annoying. And not just Caddy/GM. Lots of people complaining on the adaptive cruises for multiple manufacturers. It is hard coded by the system supplier.
The only time I didn't have cruise for extended time was when I had a problem with a parking sensor, which tripped a computer code. No cruise until the part replaced and code could be cleared.
Nope on old fashioned. You have to go all the way to the 2018 XT5 before the Adaptive Cruise allows you to revert to "classic" cruise.
Max
