does someone know how to activate the DRL in a Seville STS ´97 ?
can it be programmed on its own by entering some code ?
thanks for help, as we now have to drive with light on all day in Austria.
1993 STS, 1997 STS, 2002 SLS, 2007 CTS 3.6
They are on my 97...maybe theres a wireing problem. turn the twilight switch on and see if that works.
1999 White Diamond ETC
This is actually an IPC Override. There is a feature that sets the IPC for export country. If you set it to US, then the DRLs should come on automatically; however, you may lose another functionality designed for whatever country it was exported to.
I am not at home to post the instructions on the override. Hopefully, someone with a service manual can look it up for you in the meantime. It involves going into diagnostics mode.
