Howdy all -
I traded in my 2000 ETC on Friday for an 04 SRX-V8 (so I've done gone and changed forums
). So far, so good, with one caveat. I'm having trouble figuring out the correct answer to this issue:
According to the owner's manual, the accessory power outlets should lose power 10 minutes after the ignition key is removed/turned off. My outlets are staying on continuously (which is not what I want) :banghead: . I also see the manual says the outlets can be 'programed' to remain on permanently by moving a couple of fuses. Sooooo, I looked at the fuse block and it appears the fuses are in the correct position for the 10 minute time out.
Long question short: Does anyone else have this issue and/or so you know how to fix it?
Many thanks!
Dechief4
Many thanks!
Dechief4
