1 - 20 of 28 Posts
2009 CTS4
2009 cts4 sedan auto, 119k miles
I just got my car back from the service center a few weeks ago with new timing chains (luckily covered under extended warranty) and everything seems good during casual driving but when I try to hit the gas a little harder the engine will get jittery and seem to blip off the power for a split second at random intervals resulting in acceleration that isn't smooth. This was never an issue before the service. I thought the service guys might've not put enough fluid into the trans but I can't check easily cus Cadillac decided they were too good to put a damn dipstick in there. My other suspicion is the spark plugs are old but since this started happening immediately after the engine fix I'm not sure. Anyone ever had this issue?
'10 CTS4 3.6L Wagon prem; '06 STS 3.6L base; '98 Seville STS
Any update on this because my wagon is now experiencing the same thing. Like the engine is misfiring when accelerating, it happens between 50-60mph
Sent from my SM-N920T using Tapatalk
2013 Black Diamond CTS4 Premium Coupe (sold-09 CTS4 DI Black Raven/Ebony)
Mullah, check your plugs. These engines seem sensitive to plugs not all gapped 100% spot on the spec.
Ok so this happens at or around the 1.5-2k rpm. The spark plugs, should I replace all or which one am I replacing? Also thanks for the head ups
'14 CTS-V LongRoof; Audi RS6 Avant; '16 ATS-V Sedan gone; '10 CTS LongRoof gone
You're in there - replace 'em all
· Super Moderator
Which ac delco plug do you guys recommend? A few sites i have been on list different part numbers. 41-988 vs 41-990 vs 41-110 etc.
It is listed in your OM, IIRC 41-990.
.043" gap, 15 ft/lbs. torque. (7.5 ft/lbs. for coil).
'09 CTS DI FE1 Luxury
If you want to upgrade, 41-988 for the iridium plugs.
Reactions: Long
· Super Moderator
Correct.
OEM 41-988 (iridium) is about twice the price of 41-990 (platinum), but we're talking about ~ $20/set vs ~$30/set. Not a huge difference.
As shown in this chart, iridium scores higher in all categories.
Reactions: njlotito
So I have the plugs and Will be doing this today but the car does not have any codes or stored codes. What if it's the coils?
· Super Moderator
A failing coil SHOULD set a code.
At least you will have eliminated the plugs factor and you will have new plugs!
Reactions: Mullah88
Correct.
I ask because I seem to be having this issue or similar AFTER doing plugs. I had a coil fail, replaced all 6 just for piece of mind and figured I would do plugs while I’m in there. Now it has slight misfire that doesnt set a code.
· Super Moderator
Personally, I would think plugs would set a code, but HurstGN's post says otherwise.
Plugs on the DI are easy & cheap enough to replace and will provide a good starting point, if not a solution to your issue.
· Super Moderator
Plugs OEM and gapped correctly?
OEM coil(s)?
1 - 20 of 28 Posts
