1 - 2 of 2 Posts
I think I need an AC Comp. Makes some noise. I have put in 4 cans of 134 the car has been changed over buy a garage. no pressure what so ever, I put one can of the dye thinking it leaks so bad I would see it any where, nothing. So It's the light and glasses next. How can it leak so bad and not just show up. Don't say under the dash. that would suck. the car has 106,000 miles on it in really good shape. it's a 1991 Deville. sedan that is. thanks for any info/help.:cookoo:
If it is leaking from the evaporator it will be very hard to see any dye. Check the condensate drain. If the evaporator is leaking, you may see some dye there.
1 - 2 of 2 Posts
