Replaced ac compressor in 2015 along with new drier, orifice tube, and temp sensor. Added dye for future issues. Had no issues recharging system at the time.
I just got the ”low refrigerant a/c off” notice. Found leak at low pressure switch. (pag oil and dye all over it) Replaced with new ACDelco OEM switch and replaced shrader valve.
Check everywhere else with UV light for leaks. Found no evidence of leaks at compressor, lines, or fittings. Pulled vacuum. Trying to recharge. Compressor won’t engage. Clutch moves freely. Swapped AC relay, clutch still won’t engage. Jumped relay (pins 30/87), clutch engages and spins but system will not take charge.
If I can get the clutch to engage by jumping, what is preventing system from drawing in refrigerant? What am I missing? Thanks.
