This is for Ranger or anyone that can help. AC not coming out of dash. Coming out of windshield and floor vents. From prevoius post's on this problem, I have checked under the dash, ran the temp from 60 to 90. In the "box" where I imagine the doors are located I see the arm on top and the one on the bottom both actuate and move their full distance. The floor vents go from cold to hot and back again, but I NEVER get the air to the dash. I believe this tells me the motors are working and I do get heat and AC, but never from the dash do I get AC. I also believe from this that my vacuum is OK.What would be the next step-please. I get too dizzy from laying upside down -looking up, to do this for long. I am new to this site and would appreciate any help.
Discussion Starter #2
Found problem-help was from another thread. One of the 4 vacuum lines to the climate control was PARTIALLY off. Untill I took it out and held it close, I could not see that it was half on. Must go to the other thread to thanks those guys. Great site for info.
Glad you found it. Saved me the trouble of telling you it was a vacuum leak.
2000 Cadillac DHS
I have AC that comes out of the passenger side dash vents ONLY. Nothing out of the 2 vents on the driver's side.
Can someone point me in the right direction?
If you are talking about A/C (cool on one side only), you probably need to add a bit od refrigerant. If you are talking about heat, start by checking the DTC's. Might be an actuator. If not, maybe a heater core flush is in order.
