1 - 9 of 9 Posts
2003 Cadillac CTS
Are those the type that spin freely on the line so you can't remove them easily?
Sent from Earth II using Tapatalk V
2003 Cadillac CTS
I think it will be one of the two pictured below...
After those 2 there's only 1 more possiblity, and that's a fuel line disconnect. I don't believe that's needed here but I'll add it to the list for good measure.
Discussion Starter · #4 ·
Thank you but none of these tools work for the clamp/retainer in question.
2007 CTS 3.6 >136k miles
Check this video. Your connector appears around 5:55 time, but he only has stills for that one. Maybe it will be helpful(?)
Discussion Starter · #7 ·
Thanks, I saw that video while searching for an answer. Those clips are different. The tools being used don’t fit into any of the slots available on my clips. I’ll take some photos but keep in mind I butchered these a little getting them off. These clips wound up just taking an electrical connector plug tool to push down into the top of the latch mechanism and it popped right open. Not where ANY videos or photos I’ve found indicated the release would be. And much smaller than any tools other than electrical connector plug removal tools which is what I used.
Discussion Starter · #9 ·
Watched it again. You were correct. He shows this type right around 5:55. I hadn’t let it play out all the way. Like I tell all my junior mechanics. Keep reading. Our own words often come back to bite us in the ass. Thank you all!!!
1 - 9 of 9 Posts
