1 - 1 of 1 Posts
'08 Esky
I just started having an issue with drivers side climate control.When the temperature is on 60 degrees the drivers side blows cold air just fine but when I turn the control up to literally 61 degrees that side begins to blow hot air.The passenger side is perfectly fine.Im quite sure its an blend door actuator problem and it sounds like its out of adjustment.Has anyone dealt with this problem??
1 - 1 of 1 Posts
