03 Deville
Hey on my 03 deville the traction control abs lights come on after about half hour drive then when I get home and cut the car off it goes off then when I drive again 30min or longer it comes back on any suggestion and where is the traction control located at is there a sensor thanks
2010 DTS
There is no "traction control" unit. It is a function that is controlled by the PCM & EBTCM with inputs from the wheel speed sensors. Pull the DTC's. Post them and their definitions.
03 Deville
Sorry PCM??? the codes that I pulled are Abs1225 history Abs 1232 history IPM B0429-havac door acculator malfunction PCM p0410-Secondary Air Pump PCM 0741- torque converter PCM p1189-oil pressure switch damage that's it everything else stated nocodes for the rest any help thanks or what should I check thanks
2010 DTS
PCM = Powertrain Control Module
C1225 - Left Front Excessive Wheel Speed Variation
C1232 - Left Front Wheel Speed Circuit Open or Shorted
Check the wheel speed sensor connection on the back of the hub. If it is good, it's probably time to change the hub & bearing assembly.
