1 - 2 of 2 Posts
I have a code indicating problem with left front wheel sensor (93 Fleetwood). Both lights stay lit. A check of the wiring revealed no nicks/kinks. I removed the bolt holding the sensor to the wheel but could not get the sensor loose. Anyone know what's needed to get that bugger off? Once off, do the wires disconnect easily or is it a soldering job?
2005 CTS-V, 1994 Infiniti Q45
Im sure there is a harness connector for it......
Im sure its fused in there..... Without knowing how it goes in (it either sticks or screws in, my guess being it screws in), id try twisting and pulling while liberally applying a lubricant (doesnt sound like a sensor remoaval does it...... :D )
Someone else should chime in to give you definite answeres......
1 - 2 of 2 Posts
