I have an 2011 SRX with the ABS Traction control light on and Engine Light . Reads right rear sensor . My Question is I am starting to get Vibration in the Steering wheel but it is not all the time and it feels as though the brakes are pumping on and off on their own . Could this all be effected by the speed sensor ? Also have a popping noise which may be the CV Joint could that also be doing that Vibration on and off .
2003 Deville Base
Let's move this to the correct SRX forum. You'll get more help that way.
2014 SRX Lux
You're in the correct forum now.
The brake pumping that you are sometimes feeling is likely a traction control malfunction. That is kind of how the system is supposed to work when needed. I'm not smart on this vehicle but someone who is will be along soon. Good luck.
Well I did pull the ABS Fuse and the jerking in the steering Wheel has seemed to stop . I got the New Speed Sensor today hope to have it in this weekend .
