I have been getting a code "C1242 - Pump Motor Circuit Open" It comes on randomly and when i clear it it stays off for a while normally. I was wonderin where this problem could be originating. I read in another forum that it could be a bad wire or harness. I have located the brake valves in the lower part of the engine compartment and will check the connections there. I was wondering where the other side of the harness will plug into. An ABS control module i would imagine.
Whats weird is that it only started coming on after i had my tires balanced. Im thinking a wire may have been pinched because of that. Does anyone know if the wires are ran under the car or throught the firewall and inside?
Thanks for all the help.
